Testing digital devices
Is there any software addons for LabVIEW which automaticly generate tests for finding errors in digital devices?
Message 1 of 8
(4,385 Views)
If you are using NI hardware you can do a Self Test in DAQmx.  I dont know if this is what you are looking for though.
Cheers!
Message 2 of 8
(4,380 Views)
I am looking for software which could generate test (combinations of 1 and 0 for inputs) to check if a device works properly. Of couse, this devices are not manufactured by NI
Message 3 of 8
(4,377 Views)
This sounds like a simple program, if all you really want is randomly generated sets of 1&0's.  Have you tried writing anything to accomplish this?  What is the interface for the hardware?
Cheers!
Message 4 of 8
(4,370 Views)
if tests are generated randomly this garntees only a certain probability that a device is ok. There is a mathematical approach to generate alpha-tests (to test all possible signal paths), beta-tests (test compensatory paths), OV-tests and so on. The whole algorithms here are rather difficult, they based on directional derivatives from logical functions...
Message 5 of 8
(4,363 Views)
I see, I miss understood what you were after.  As far as I know LabVIEW doesnt contain the prepackaged testing programs you are looking for.
Cheers
Message 6 of 8
(4,361 Views)
An interface doesn't matter.
Message 7 of 8
(4,360 Views)
Many thanks.
Message 8 of 8
(4,357 Views)
