Text Ring multiselect mode
I want to make a drop-down box in my program, works like a drop-down menu with multiselect mode, use shift key and ctrl key.
Does Labview has this type control?  I find combo box, text ring and enum can't meet my requirement.
(7,182 Views)
It is called a listbox under the List, Table, and Tree pallete.  There are settings to allow for multi-select.
(7,176 Views)
Accepted by topic author concorpoly
There is no such control. There isn't even one of those in Visual Studio. A dropdown is intended to select one item. If you need to select multiple items then you could use a ListBox. You could also have it so you have a menu ring on the front panel, and when the user clicks on it, you show a ListBox whcih is normally hidden. This gives you the illusion of a dropdown with multiple selections.
(7,173 Views)
Neither Ring nor Enum could be in the multiselect mode. Refer to the Listbox that could function as you desire. See the attachment for details.
(7,155 Views)
Thankyou RyanWhite..
This solved my requirements..
Thanks & Regards,
Ilamparithi Tamizhanangu
(6,549 Views)
