Text label alignment off on diffrent computers
When I send an executable to another computer the text label alignment is off. Please see attachment for example.
(3,558 Views)
Have you by any chance checked the "Maintain proprtions" option in the VI properties? if so untick it and build your exe. It will be fixed..
Nitz
(Give Kudos to Good Answers, Mark it as a Solution if your problem is Solved:smileywink:)
(3,556 Views)
They look like different fonts and different sizes.
Any chance you are running two different operating systems such as XP vs. Win7?
See Why does my block diagram change when I copy my code to another system?
(3,544 Views)
Yes, Target computer is win 7 and development computer is XP
(3,540 Views)
That is the problem then.
Read that link I sent.  And search for Windows and font and you might find other threads where the issue was discussed.
I think the solution for you will be to define the application font in your LabVIEW.ini file, or in the application's .ini if you build it into an executable to be a specific font and size such as Tahoma 13 (double check that size) so that it will match the default font that LabVIEW uses on an XP machine.
(3,532 Views)
