Text string to 2d array
May i know how can i convert the data string into array?
I need to convert the string data to array.
For example, for the data shown:
I want to remove the first 2 headers:
Then only kept the only the 4th,5th and 6th columns of each row.
 #123 remove
#324 remove
1 2 3 4 5 6
1 2 3 7 8 9
1 2 3 4 5 6
3 2 1 6 4 2
To become:
 4 5 6
 7 8 9
 4 5 6
 6 4 2
and saved them into 2d array of 4x3
(4,572 Views)
Dear all,
Can it still run fast if it has around 15 k rows of data to sort and change to array?
Thank you!
(4,570 Views)
Accepted by topic author Joven
Open the file, read the first 2 lines using the Read From Text File (right-click on it to enable reading lines and set the count to 2), then read the rest of the file, use Spreadsheet String To Array to convert to a 2D array, and finally use Array Subset or Delete From Array to reduce to just the columns you want.
(4,548 Views)
