Text to binary, binary to text.
Ok, we got it to work now that we got rid of the dynamic data. Thanks!
As of now though, we can only read one character at a time. We're thinking that somehow creating a new element in the array every 8th bit sent would be a soulution, but again, we don't know how.
This is the current state btw:
Message 11 of 12
(1,396 Views)
Yes, you are very close Smiley Happy
You need to use a shift register to hold either the array of U8s or the string in memory and append to it every time you get a new character. Also, the outer for loop is completely unnecessary. Remove the outer for loop and use a concatenate string like this:
Each time the loop runs, it will add the new character to the end of the read string. You should be able to modify your VI to do this.
I suggest you have a look at some of the LabVIEW training - you're struggling here with some pretty basic concepts that would easily be covered with some of the free training materials that NI provides. http://www.ni.com/getting-started/labview-basics/
(blog)
Message 12 of 12
(1,379 Views)
