Thanx plainman
thank you very much..but what is NI's developer?!?thanx
(2,668 Views)
Sumara;
"NI Developer Zone" is a section at NI website dedicated to developers that use National Instruments products. The following link will take you there:
http://zone.ni.com/zone/jsp/zone.jsp
Because you are interested in LabVIEW, you can go directly to the LabVIEW Zone.
Looking at your previous question, LabVIEW already ships with very good examples. Usually, you can access the examples from the Splashscreen (the window that read LabVIEW), there is a button that reads "Search Examples". There is another that read "LabVIEW Tutorial". (If you can't read that, change the switch to Large Dialog).
If you have a VI window already open, you can
search examples from the help menu -> examples.
Regards;
Enrique Vargas
www.visecurity.com
www.vartortech.com
(2,668 Views)
"Enrique" ha scritto nel messaggio
news:50650000000500000084580100-1075935269000@exchange.ni.com...
> Sumara;
> you there:
href="http://zone.ni.com/devzone/labviewzone.nsf/OpenPage?openagent&lvsectio
n=labviewzone">LabVIEW
at read "LabVIEW
> Dialog
> If you have a VI window already open, you can search examples from the
> Regards;
> Enrique Vargas
> www.visecurity.com
thank you very much
(2,668 Views)
