09-19-2007 01:25 PM
I won't dispute that the release dates are most likely enforced (programmers are never ready), and I didn't use 8.2 (or 8.2.1 or 8.5, for that matter), so I'm not the proper person to comment about the readiness of LVOOP in 8.2.
However, I did try to follow the discussions about LVOOP and my *impression* was that LVOOP in 8.2 had several big bugs, a lot of edit time issues and had problems with support in the RTE. I wouldn't call that "not ready".
Granted, I also ship all my applications as deployed executables and I wouldn't want to find that a feature my application relies on will not work in an executable, but I would be very careful with a new feature anyway, since I know there are features which only work in the IDE.
In any case, if NI hadn't shipped 8.0 and 8.2, it probably would not have been ready in 8.2.1. Eventually, you release your product and find that there are bugs that you didn't catch either in your design and testing or in your betas (for example, that "double-click the icon" the bug). You can't guarantee that a bug will be caught in a beta, especially if it is in a new and complicated feature which people don't necessarily have time to learn and use.
If you have any more criticism, I suggest you post it here.
09-19-2007 02:47 PM - edited 09-19-2007 02:47 PM
I'd rather post on NI's own site. I'm NI's customer.
No I've done it, LVOOP wasn't ready until 8.2.1. And they could have easily found most of those bugs by just creating a medium sized LVOOP project and building it into an exe and installation. It didn't take outside developers to find them, most of them are obvious if you try to build a real project in LVOOP.
Message Edited by billings11 on 09-19-2007 02:49 PM
09-19-2007 03:01 PM
Fair enough, although I know I would follow LAVA for that since that's where most serious users of LVOOP post and where you have the designer of LVOOP available to answer. It's a simple matter of practicality.
09-19-2007 04:20 PM
09-20-2007 08:12 AM
09-20-2007 12:29 PM
We're not saying that there are no bugs, just that your description of NI's process is false.
I've had the chance to use the PDA module in its first versions. That was definitely a half baked product, but it was ready - you could produce applications. You just had to take into consideration that there are a lot of bugs which you will need to work around, even if you paid good money for it, and work that into your development schedule. That's sometimes the price of using a first release.
I haven't had a chance to use the last couple of versions of the PDA module, but I understand that there were improvements and a lot of them probably came about because customers said "this is what we want and need".
Anyway, I know that if I had the R&D guy ask for feedback and be available for questioning, I would go and talk to him instead of going through the AEs (which is not to say that gmart is an AE) or just venting.
Ultimately, you have two productive options -
09-20-2007 02:46 PM
09-20-2007 03:15 PM - edited 09-20-2007 03:15 PM
Message Edited by billings11 on 09-20-2007 03:17 PM
09-20-2007 03:33 PM
I would guess it was the first, but the easiest way to get a qualified answer would be to ask AQ (or gmart, since if memory serves he\she worked on the app builder and would probably know).
@billings11 wrote:
Probably NI did test building exe's with LVOOP and decided to release knowing workarounds would be required. Either that or they never tested building an exe with LVOOP. But it has to be one or the other right?
09-20-2007 10:14 PM
