The Cycletime of a while loop?
i want to know the cycletime of my while loop?
How can i write this in an array?
Thanks for your anwers
HRC
(3,347 Views)
Use a shift register to remember the value of the ms counter (Time & Dialog palette) and subtract the current value. Note the use of the sequence structure to make sure the time is taken only when the loop finished executing its code.
___________________
Try to take over the world!
(3,342 Views)
HI,
thanks for the answer, is that the only way to see the cycletime of a while loop?
I tried it but in the array are no data, also if had stopped the vi.
(3,339 Views)
Hi
ok now i see data in the array but the data don't stay and fill the array, how can i do this?
Than i have the wait until next ms multiple in my vi, tha time is 1 second. When execute the vi i thought that the time value should be stabil on 1000 ms but it jumps every iteration from 52 to 451 or to 987 and so on.
What is the problem?
(3,330 Views)
The only way the array can have no data is if you click the abort button. If you clicked the stop button the array should have a very (very) long list of 0s (with a rare 1), because the minimum is 1 ms and since this loop does nothing, it can run a great number of times in a single ms.
If your loop will take longer to execute, you will see the result.
___________________
(3,327 Views)
You should read the help for it. Wait until next ms multiple does just that - it waits until reaching a multiple of the ms counter. That means that depending on how long your code actually takes to execute, you may get some variation. If you want a rigid wait, use the Wait function instead. You might get some jitter here as well, but it will be much smaller (on the order of a few ms). Have a look at this for a good explanation.
___________________
(3,322 Views)
