Home
Community
Discussion Forums
Most Active Software Boards
Topic
Register
Login
Help
Community
Category
Board
Documents
Users
Turn on suggestions
Auto-suggest helps you quickly narrow down your search results by suggesting possible matches as you type.
Topic Options
Subscribe to RSS Feed
Mark Topic as New
Mark Topic as Read
Float this Topic for Current User
Bookmark
Subscribe
Mute
Printer Friendly Page
All Forum Topics
Previous Topic
Next Topic
The File ABC.vi is not a VI. Select another?
Homero
Member
10-21-2004
10:24 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Report to a Moderator
When I attempt to open some of my VIs, I get an error: The file abc.vi is not a VI. Select another?
0
Kudos
Message
1
of 3
(2,658 Views)
Reply
Re: The File ABC.vi is not a VI. Select another?
markwysong
Active Participant
10-22-2004
09:39 AM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Does it actually say "abc.vi"? Sometimes when I save a VI, it doesn't put the .vi extension, so when I try to open it, it won't open. I have to manually rename the file to put the .vi extension, and then it will open.
0
Kudos
Message
2
of 3
(2,658 Views)
Reply
Matt_F
NI Employee (retired)
10-22-2004
04:11 PM
Options
Mark as New
Bookmark
Subscribe
Mute
Permalink
Print
Hello Homero,
The two KnowledgeBases linked below address the issues of LabVIEW reporting a VI is not a VI.
Why do I Get the Error "The File xxx.vi is Not a VI. Select Another?" When I Try to Open a VI on a D...
Why Do I Get "The file xxx.vi is not a VI. Select another?" on Windows 2000?
If these KnowledgeBases do not address the issue, we will need to look more in depth on what has changed since the VI was last successfully opened.
Matt F
0
Kudos
Message
3
of 3
(2,658 Views)
Reply
All Forum Topics
Previous Topic
Next Topic
