The Functions pallet will not come up
Everything was working fine yesterday, when I had two monitors hooked up, but now I am home working on my laptop, and I cannot get the Functions Pallet to become visible.  I click on the "Functions Pallet" field in "View" and nothing happens.
Any help would be greatly appreaciated.
Forbes Black
Lapsed CLAD, LV 5 - LV 2022 (Yeah, I'm that old...)
(3,229 Views)
Might it be hidden off screen where your OS thinks there is still a second monitor? If you've got another screen around try plugging it in and see if you can find the palette there
_____________________________
- Cheers, Ed
(3,222 Views)
You can also try finding the line holding the position in the LabVIEW.ini file and deleting it and then restarting LabVIEW. It should probably reset it.
___________________
Try to take over the world!
(3,202 Views)
Accepted by topic author diarmaede
Or just "right-click" on the block diagram to get the palette at the cursor postion and then press the push-pin to tack it down if you really want to.
(3,193 Views)
