The Governing Library for this node is broken
When i drop my match regular expression node. My VI is getting broke and the error message what i get is "The Governing Library for this node is broken" Can anyone tell me why this is happening ASAP. Do I need to reinstall LabVIEW.
(4,651 Views)
Which version of LabVIEW are you having this issue with and is it on a fresh install?  Before reinstalling LabVIEW, have you tried to 'Repair' the current installation?
To Repair your installation go to Control Panel >> Add/Remove Programs >> National Instruments Software >> Change >> Select your LabVIEW version >> Select Repair.
Do you have any other background information regarding this issue?  Can you reproduce the broken run arrow by creating a blank VI and creating a Match Regular Expression node?
Let me know what you find.  Cheers!
(4,631 Views)
I just upgraded to 8.5.1
I get the same error when I open a VI that uses Timed-While loops.
8.5.1 crashes when I drop a timed-while loop onto the block-diagram.
I am reparing the installatin (hopefully, this will work)
(4,490 Views)
Nope
(4,479 Views)
Please continue discussion in the new thread.
(4,465 Views)
