The LV crashed when I call a dll to control my com port
Yaoming wrote:
> Does there nobody be able to help me to solve this problem? 😞
It's very hard to help you here. I gave all possible suggestions I could
think of, and I can't even try out the DLL myself as it is HASP
protected, so my options are all used up.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 11 of 15
(1,051 Views)
Thanks for your help any way.
Going on looking for solution.........
Message 12 of 15
(1,038 Views)
Did you check the calling conventions? Windows uses _stdcall other DLL's may use C calling conventions. You can set this option in the Call Library dialog box. I commonly don't do this correctly myself, so it may be worth a try.
Message 13 of 15
(1,029 Views)
jpeters 写:
Jpeters,
I have tried the two calling conventions already. If you use standAPI, the LV could crash even when you begin to run the vi. However, if you use C code, the LV only crashed when you tried to close the LV application after the successful running vi.
So the standAPI calling convention is the worse situation.
Message 14 of 15
(1,022 Views)
Just another thought because we have exhausted all the other options...
When I make dll calls I pass the handle by value rather than pointer to a value. I know with the documentation the DWD_set_comport function says it should be a pointer but have you tried just passing it by value? I am just curious, perhaps the documentation could be wrong, I have seen that before. So, if it is still not working and you get the chance to give it a try see if that changes anything.
Unfortunately without the key were kinda stuck. Best of luck.
-Dave
Message 15 of 15
(1,015 Views)
