The LabVIEW DLL Builder is not registered with the system
When trying to Build LabVIEW code into a DLL with LabVIEW 8.20 Professional I get the following error:
Error -2147221164 occurred at Building DLL stub.
The LabVIEW DLL Builder is not registered with the system. Reinstalling the Application Builder or Professional version should correct this problem
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
I've tried reinstalling LabVIEW 8.20 Professional, but it hasn't fixed it, can anyone tell me which DLL is used for the LabVIEW DLL Builder, and I'll try registering it manually.
A.
(2,858 Views)
Hello ADL,
Have you tried this KnowledgeBase ??
Chetan K
(2,847 Views)
