The .NET assembly expected to be at "" was loaded from "NULL"
I use NET Components in a LabVIEW 8.2.1. VI and all work very fine. Now I convert it to LabVIEW 8.5 and I always get a warning, when open it.
The Warning is :
 The .NET assembly expected to be at "" was loaded from "NULL".
As example I add my CallbackVI in the Attachment. If somebody has an idea to remove this warning I would be thankful.
Thanks in advance
(3,153 Views)
Traxx,
this is a known issue in LabVIEW 8.5 and NI is working on it with high priority.
Please have a look at this thread for more information. Some users have found a solution by mass compiling their projects. This is discussed here.
Sorry for any inconvenience.
Kind regards,
Jochen Klier
(3,132 Views)
Thanks a lot - this was the problem.
I always recompiled with STRG+ALT+Click on play arrow. With a mass compile from this directory all works fine.
Great - thanks
(3,127 Views)
Oh I was glad to early.
The problem was only solved one time. When I changed something and saved again, I had again the troubles.
I will recreate the VIs now. I already done, but it didn't helped. Now I read, that old one should be closed.
(3,119 Views)
