The RT target does not have enough memory to load the startup application
the title of this post is the error I had while I tried to deploy a RTexe to a sb-RIO: (0x63B) The RT target does not have enough memory to load the startup application
As I have read THIS artikel, I tried to sustitude the rtexe file through FTP and restart the ab-RIO. The FTP connection is built up using the "FTP file to sbRIO.vi" which is in the attachment. I have just overwritten the rtexe file but not the other project files.
If I tried to deploy the rtexe using the project explorer and set as startup, it can be restarted and run properly.
Wilbur
Message 1 of 1
(2,412 Views)
