The TDS 2004C driver from NI website does not wrok.
I try to use TDS 2004C oscilloscope as a data logger, but the driver downloaded from NI website does not work.
(3,190 Views)
How does it not work?  Are you getting an error?
(3,183 Views)
Yes. The error says that some of the items were removed from the project. But I have no clue about where to find the missing items.
(3,179 Views)
Which driver did you download?  It looks fine to me.
http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=047216EC20B66FABE0440003BA7CCD...
(3,173 Views)
I downloaded the 2012 version from the same link. I can unzip it, but the examples do not work for me.
(3,166 Views)
It sounds like you just did not unzip it to the correct location. Using Help> Find Instrument Instrument Drivers would have installed it to the correct location. Otherwise, follow the instructions on the download page for installing to the instr.lib folder.
(3,152 Views)
Where did you unzip the files to?  The zipped up folder needs to go into your <LabVIEW>\inst.lib folder.
(3,118 Views)
