The VI VISA:Write does sometimes not finish execution! What can be the reason for this?
Hi everybody, I already posted this question in the Hardware Boards, but maybe this was not the correct forum as I do not get any replies. So I'm now trying to post this in the general LabView Forum as I am quite desperate to find a solution for my problem!
I truly hope someone can give me a hint how to solve this ...
I have got a problem with the VISA:Write VI in LabView 2009 SP1 32bit (WinXP). When using it to communicate with a serial RS232 device the VI sometimes does not finish execution. Sometimes this happens after 2 or 3 consecutive calls, sometimes only after some thousand calls. When using the "Highlight-Function" one can see that the VI gets called correctly but it will NEVER finish, issue any kind of error message and of course also not hand any output-arguments to the subsequent VIs what causes the whole application to freeze. The Win Task-Manger shows no increased CPU-Load while "permanently executing" VISA:Write. The only possiblitiy to stop the execution is to push the "Close Button" of the Top-Level VI Window. The "Stop Execution" Button will be ignored. When forcing the application to quit, LabView shows a small message window that it is "Resetting" the Top-Level VI. This will also never finish. LabView can only be stopped by using the Win Task-Manger.
As this happens when using the Built-In COM Ports as well as when using those provided by a PCI Port Extension Card I am quite sure that it is no IRQ or Memory collision problem.
Can anybody give me a hint what is causing this problem and how I can find a workaround?
Thanks in advance and best regards,
Robert
(2,893 Views)
Duplicated post, please continue on this thread:
http://forums.ni.com/t5/Instrument-Control-GPIB-Serial/The-VI-VISA-Write-does-sometimes-not-finish-e...
Christian
(2,860 Views)
Dear Christian,
as you can see from the first sentence of this post I'm fully aware that this is a duplicate thread, and I know it's "bad habit" but as you can see, I did this for reason. Anyway ... thanks for pointing out my wrongdoing!
Do you also have a hint for solving my problem?
Robert
(2,851 Views)
Christian has already responded to your question in your original thread. Please keep the discussion in that thread so all pertinent information is in one place. Thanks.
(2,829 Views)
