The application is not able to keep up with the hardware aquisition - module 9237
I attached my vi as follows. I have read some related posts and understand the possible reason is my write function costs resources. But this is not a high frequency data acquisition sinceI have reduced the sampling rate of 9237 to be very low (2000 Hz). Why would this happen? Any method to fix it?
(632 Views)
I'd review this article:
https://www.ni.com/en/support/documentation/supplemental/06/learn-10-functions-in-ni-daqmx-and-handl...
and get rid of your DAQ Assistant node. You could try right clicking the DAQ Assisstant and converting it to a subVI, then reviewing the generated code, but I'd just start from scratch using the "real" functions myself.
(615 Views)
