The attached VI works when I run it initially creating the XML file, but when run after the XML file is created, it's not updated. What am I doing wrong?
The attached VI works when I run it initially creating the XML file, but when I change data and run after the XML file is created, it's not updated with new data. What am I doing wrong?
Thank you.
(2,340 Views)
Accepted by topic author chuck72352
That looks like the logic which was written into the VI
Inner true/ false case:
(file exists : false) write to XML file, unflatten for display
(file exists : true) read from XML file, unflatten for display
At no time when the file exists (true case) is the XML file updated...
(2,335 Views)
