The build works not the same as the vi in the project
I have problems with the exe file. I made a very easy example of what happens. To test it JKI - String-Based Queued State Machine (Basic) v1.0 (openg) is needed.
I made a sample program with uses the JKI - String-Based Queued State Machine (Basic) v1.0
When I open the project and run the test.vi the light will go on. When I press OK the light will be in the off state and the program waits for 2,5 seconds and then close.
This is the way I want to run the program.
From this file I make an executable and run the program. The light will turn on, but when I press OK the program shuts of without waiting. What do I do wrong?
Rens
The attached test.zip folder are the project files with 2 vi's included. (test.vi and test2.vi)
The attached application.zip is the executable from the labview program above.
(2,406 Views)
Accepted by topic author RvG
problem solved
(2,383 Views)
