The compilation failed due to a Xilinx error.
used hardware: Compact Rio 9035 and NI 9853
used software: Labview 2017
When i compile the VI "CAN Signals Transmit FPGA.vi", i have this message:
LabVIEW FPGA:  The compilation failed due to a Xilinx error.
Details:
ERROR: [Synth 8-1031] cincorrectmodule is not declared [/opt/apps/NIFPGA/jobs2/VWAs7wP_K2iuqv0/Slot_4.vhd:6637]
INFO: [Synth 8-2810] unit behavioral ignored due to previous errors [/opt/apps/NIFPGA/jobs2/VWAs7wP_K2iuqv0/Slot_4.vhd:6555]
INFO: [Synth 8-2810] unit propertycontrolp1slot_4 ignored due to previous errors [/opt/apps/NIFPGA/jobs2/VWAs7wP_K2iuqv0/Slot_4.vhd:7080]
Finished RTL Elaboration : Time (s): cpu = 00:00:06 ; elapsed = 00:00:32 . Memory (MB): peak = 1014.520 ; gain = 177.285 ; free physical = 28246 ; free virtual = 29434
RTL Elaboration failed
INFO: [Common 17-83] Releasing license: Synthesis
9 Infos, 4 Warnings, 0 Critical Warnings and 2 Errors encountered.
synth_design failed
::RTL Elaboration failed
    while executing
"source -notrace ./.Xil/Vivado-2344-ip-10-0-53-140/realtime/toplevel_gen.tcl"
    invoked from within
"synth_design -keep_equivalent_registers -top "toplevel_gen" -part "xc7k70tfbg676-1" -flatten_hierarchy "full""
    (file "/opt/apps/NIFPGA/jobs2/VWAs7wP_K2iuqv0/synthesize.tcl" line 21)
    invoked from within
"source "/opt/apps/NIFPGA/jobs2/VWAs7wP_K2iuqv0/synthesize.tcl""
# exit
INFO: [Common 17-206] Exiting Vivado at Thu Jun 14 12:43:31 2018...
Compilation Time
Date submitted: 14/06/2018 14:42
Date results were retrieved: 14/06/2018 14:45
Time waiting in queue: 00:19
Time compiling: 02:49
- Generate Xilinx IP: 00:00
- Synthesize - Vivado: 01:41
 Please, can you help me!
Thank you in advance.
(3,203 Views)
Hello
On Windows 10 there are some known problem to compilate your FPGA code. You must use the server compilation. Here there is a link which explain the purpose :
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019R0PSAU
(3,169 Views)
