The generation data position is on wrong edge
I'm using a HSDIO 6541 with LabWindows, drivers version 1.5.1.
I noticed that when I configure the DATA_POSITION attribute on my GENERATION session, if I choose RISING_EDGE, the data is actually still on FALLING_EDGE and changes on RISING_EDGE, and if I choose FALLING_EDGE, data is still on RISING_EDGE etc...
This doesn't happen on Acquisition session, the sampling surely happens as defined by the attribute.
So the attribute DATA_POSITION seems to be inverted, only on generation sessions.
Antoine
(2,695 Views)
You might want to repost this to the LabWindows forum. It'll increase your chances of getting an answer.
Mike...
Certified LabVIEW Architect
LabVIEW Champion
(2,677 Views)
Oops you're right.
I must have done a wrong click somewhere.
Applying your wise advice right now.
Antoine
(2,639 Views)
