The in Range and coerce. vi doesn't work.
The in Range and coerce. vi doesn't work. The booleen ouput doesn't change no matter what the input. The coerce function appears to work correctly. Do I simply have a bad vi?
(2,842 Views)
It works fine for me. Post an example of the bug you are seeing.
Tim
(2,842 Views)
I have a simple example written in LabVIEW 6.1 with the In Range and Coerce VI. This works for me. If it doesn't for you then there might be something corrupt with the VI.
(2,842 Views)
