The interface of LabVIEW can be hided in the VI not running?
I use LabVIEW 6i to programme .Now I can hide the interface of LabVIEW in the running of programme.I can hide it when the VI is not running?Only vI emerging in the screen can be realized ?
Birnny
(2,784 Views)
vi server lets you make this programatically.
Look attached vi. It make itself unvisible during running. After that you open it again from File/Open ,you will see that it still running.
(2,784 Views)
If you want to change properties of your vi when it is not running, open the vi then go to File>>VI Properties and for Category, select Window Appearance. Clicking on Customize will open a dialog and unchecking the options will remove those options the vi. You can select different properties for each vi.
Ray K
(2,784 Views)
