The modified thompson tau technique
 I would like to remove outliers from data with the modified thompson - tau technique,
do somebody create the VI for the modified thompson - tau technique?
I would appreciate it if you would let me know if the VI is in libraries of LabVIEW(ver. 8.6).
Regards
naisty
Message 1 of 10
(9,663 Views)
I am very interested in details about this technique.
The only VI I know about for removing outliers is the quite weak Remove Outliers VI.  This VI only allows you to remove outliers based on an X and/or Y Range you must specify or Indexes; quite pathetic really.
It would be nice for this VI to have at least the in-built capability to remove outliers based on standard deviation..
Remove Outliers VI.pngSmiley Indifferent
Message Edited by battler. on 03-12-2010 01:50 AM
Message 2 of 10
(9,654 Views)
Method is explained quite well here:
http://www.mne.psu.edu/ME345/Lectures/Outliers.pdf
It is not difficult to program.  The hardest part would be calculating the modified Thompson tau value which is calculated from the critical value of the Student's t-test.  You could use the tabulated values for Thompson tau but Ithink it would much more flexible to calculate based on arbitrary n number of samples.
You need the critical students t-value for error = 0.05 and degrees of freedom = n-2.
With the method only one outlier is considered at a time, subsequently removed and Thompson tau recalculated.. and so on.
Message 3 of 10
(9,651 Views)
Thanks battler.
I have made a VI for LabVIEW 8.6 to remove outliers with the technique.
thx,
naisty
Message 4 of 10
(9,623 Views)
Well done naisty.
I'm not too sure about the sequence structure - I think it could be done a bit better.  I tested your VI and it appears correct.
The calculation of the modified Thompson tau is correct against the tabled values given by the reference.  I tested it against the Example for no outliers.
I'd be interested to see the perfomance of this technique for a wider variety of datasets.
Note: it is only suitable for removing outliers in a sample of a single variable.
Questions for naisty:
- What are you using it for?  Can you post some typical data (re-post the VI and set the input array with your data to Default values) or plots.
- Do you know of a textbook reference for the modified Thompson Tau method?
Message 5 of 10
(9,616 Views)
Thank you for your reply and questions.
I'm trying to figure out a judging algorithm based on the outliers.pdf for a wider variety of datasets.
The VI is still in the make due to the subjective second criterion.
For my research. ( http://mswebs.naist.jp/LABs/kawai/tsumatori/ )
Specifically, I'd like to obtain the correct average value from acquired signal by the optical system I designed.
I've found some references about this method.
  Title: Measurement Uncertainty
  ASME Performance Test Codes
  Publisher: The American Society of Mechanical Engineers (ASME)
  Title: Introduction to Engineering Experimentation
  Authers: Anthony J. Wheeler,Ahmad R. Ganji
  Publisher: Prentice Hall
  pp.163-
  Title:  Rapid Quantitive Analysis of Magnesium Stearate
           in Tabulates Using Laser-induced Breakdown Spectoscopy
  Authors:   St-Onge, L., Archambault, J. F., Kwong, E., Sabsabi, M., Vadas, E. B.,
  Publisher: Journal of Pharmaceutical Science,
  vol. 8, pp. 272-288
naisty
Message 6 of 10
(9,586 Views)
Hi naisty,
It would be nice to have implemented the method for pair of (x,y) variables.  Please do post.
I can't ready much of that research page 😉
Thanks for the references.  I will try to find these and others in order to implement a better method for removing outliers.
Battler.
Message 7 of 10
(9,556 Views)
Hello battler,
I've crated the new VIs for removing outliers and testing.
This VI support two variables.
In order to evaluate the subjective second criterion in the outliers.pdf,
I used the correlation coefficient.
the flow chart of the VI is here.
1. single variable?  -- y --> removing outliers by the thompson - tau method  --> exit
2. using the specified curve fitting order, getting the pairs of x,y value of the fitted curve and the correlation coefficient, r.
3. evaluating standarized residual, |e/S|.  (all of |e/S| < 2? --y--> exit)
4.  r >= 0.99? -- y --> exit
    ( this condition may be not necessary. )
5. if r <= 0.95, removing suspected outliers. else (that is, 0.99 > r > 0.95), adding 1 to the fitting order.
6. return to 2.
Could you test these VIs?
(Please save both files to the same directory.)
naisty
Message 8 of 10
(9,528 Views)
Hi naisty,
Thanks for posting.  I will test ASAP and let you know.
Battler.
Message 9 of 10
(9,488 Views)
I looked briefly at the VIs.
I think that it is simple enough (and there is little doubt) to show that you have impemented the method described in that paper correctly.  I will get around to that over the weekend.
It is another thing (and what I'm really interested in) to test the behaviour and performance of the method.  I think it needs to be compared with removing outliers using say 2-3 standard deviations.
Message 10 of 10
(9,468 Views)
