The number of channels in the data does not match the number of channels in the task
Hello
The attached VI modifies an input signal (train pulse). The signal is delayed (t1, t2, ti) and it will stay like that for an amount of time (T1,T2,....Ti). After processing such signal, the result will be an input signal for an electronic circuit.
The main problem is when the DAQ Assistent is set, and gets the processed signal, for putting it in an analog output
Thanks in advance
(4,333 Views)
Well, you are giving it a waveform to output when you configured the task for 1 sample.  Try changing to N samples or to Continuous Samples for the Analog Output.
(4,312 Views)
When i try to choose in the daq assistant interface the option of continuous samples or N samples, the following error shows up (see attached image).
(4,273 Views)
I forgot....I am using the NI USB-6008
(4,266 Views)
That is a problem.  The USB-6008 only has static analog outputs.  This means that you cannot output waveforms at the rate you are trying to accomplish.  Maybe the USB-6003 can do what you want.
(4,253 Views)
John,
     Are you by any chance a Student?  If so, invest in an NI MyDAQ, which has far more capability than the USB-6008, can output analog waveforms, and is amazingly inexpensive for students.  A number of excellent Biomedical Engineering programs require that Freshmen purchase one (cost is comparable to a good textbook, maybe two), and they find that they use it all the time in their Instrumentation and similar Labs.  Plus they can take their circuits home with them and do "home-work".
Bob Schor
(4,225 Views)
