The pop up menu of “VISA resource name” comes nothing except refresh.
I need help!
I connect the Agilent 33220A to my computer through Agilent 82357B USB-GPIB cable. Both Agilent connection expert (Agilent IO control) and NI-MAX can detect the equitment and query the *IDN? successfully. I when I want to use the driver example in lab view 2015 (Agilent 33xxx series), the pop up menu of “VISA resource name” comes nothing except refresh.
I already reinstall NI-VISA driver even the whole Lab View package, but it not work. Below shows my MAX (GPIB::10::INSTR is 33220A).
Message 1 of 30
(5,647 Views)
Check whether GPIB Interface drivers are installed while installing Device Drivers?
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
Message 2 of 30
(5,615 Views)
Install the drivers from here and then see if it works: http://sine.ni.com/apps/utf8/niid_web_display.download_page?p_id_guid=0470714759413BCCE0440003BA7CCD...
uday
Message 3 of 30
(5,610 Views)
Right click on the VISA control and check what settings are present under I/O Name Filtering.
Message 4 of 30
(5,600 Views)
Hi Peter,
what happens when you replace the VISA IO control with a simple string constant containing "GPIB0::10::INSTR" (without the quotation marks)?
Message 5 of 30
(5,596 Views)
It shows this
Now the situation is both MAX or Agilent IO can find 33220A, but in Lab View, it can not find 33220A, I do not know why and what should I do.
Please help!
Message 6 of 30
(5,566 Views)
Follow Ravens Fan's advice
Message 7 of 30
(5,561 Views)
Thanks for answering me.
I bought the 82357B USB-GPIB cable, and installed the Agilent IO control software, Is it the GPIB interface drivers?
I can query *IDN? successfully and MAX also can find USB-GPIB, is it means the USB-GPIB works well?
The problem is that the labview program can not find it.
Thanks for you remainder.
Message 8 of 30
(5,559 Views)
I also have the same setting, but it not work.
Message 9 of 30
(5,555 Views)
If you are refering to the settings shown in my second capture in my last post.  It won't work! share a snip of your settings
Message 10 of 30
(5,551 Views)
