The problem of change the value of boolean during the runtime
Hello everyone,
I am making a subvi in a project, here is my subvi. So in my subvi, the program can well automatically stop and the boolean 'Tourner' will turn to false.
But when I delete the loop while and add rest of subvi to my project which is an exemple of stepper motor named '9503 Stepper Drive(Torque Smoothing Coeff)', this part can only stop for a little moment and continue running, I don't know where is the problem, if someone could help me please? Here is also my project vi.
Thanks a lot.
(2,737 Views)
Could you elaborate a bit more on the sections of code and similarly provide the project files rather than images?
I would think that the approach needs to be different but it would be best to understand the whole system and the actual need for this functionality to best advise.
Additionally I would refrain from having backwards wires.
Ed
(2,652 Views)
Thank you for replying me. Now I am using these codes (actually this is a project) for controlling a NI stepper motor, I am running with NI cRIO 9035 and NI 9503. I will send you the project files tomorrow.
Thanks a lot!
(2,625 Views)
Check the mechanical action of "Tourner" It needs to be "Switch when released"
(2,616 Views)
