The problem of data combination between different while loops
Three different while loop boxes have always produced different data. Now I want to combine the data of the three loop boxes in order, such as the first loop box with 200 data, the second loop box with 300 data, and the third loop box. 400 data, combine them into a 900-size result data frame, and continuously output, how to achieve?
(1,623 Views)
are you trying to concatenate multiple arrays into 1 array?
If yes, you can use build array function, detail may refer to this KB:
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019MORSA2&l=en-MY
Btw, I saw you post same question in mandarin post link
If you wish to discuss in mandarin, here is suggested community link:
for simplified Chinese:
https://forums.ni.com/t5/NI中文技术论坛/ct-p/ZHSForum?profile.language=zh-TW
for traditional Chinese:
https://forums.ni.com/t5/NI台灣-技術論壇/ct-p/ZHTForum?profile.language=zh-TW
(1,599 Views)
