The problem with the strings Convert each other
Hello all,
  Could you help me to solve the following problem using LV7.1? Thank in advance.
  How can I convert a string of "hexadecimal value" with Normal display style to other string of " the same hexadecimal value" with Hex display style?
Evan_Lv
(2,913 Views)
Hi Evan,
look at the attachment Smiley Wink
At the moment there is no error checking (any characters other than (0-9|A-F|a-f) will give an error; only even number of chars is converted). You can do the error checking
as an exercise on your own!
Message Edited by GerdW on 08-21-2007 09:08 AM
(2,900 Views)
Here's a more compact alternative. Same result and same precautions. (It acts a little bit differently if you string has e.g. spaces between hex paris.)
Message Edited by altenbach on 08-21-2007 12:56 AM
(2,893 Views)
