The "Skip Key" in set tabbing order. Where is it?
Setting the front panel tabbing order in LabVIEW 6.0.2. The user manual says there is a "skip this control when tabbing" check box in the key navigation dialog box. I can't find it, does anyone know where it is?
(2,656 Views)
This is an attribute of individual controls.
Right click the control you want to skip, select Advanced>>Key navigation...
In the panel that displays there is the 'Skip this control when tabbing' option.
Roberto
(2,656 Views)
