The same number is written to the array.
Hello! I'm working with NI myRIO, in Labview 2013. In my work, an electret microphone was designed. My country was recording data, from a microphone, to an array of nx1 (n-lines, 1-column). But in my case, the same number is always written to the array. File attached.
(4,057 Views)
Здравствуйте! Я работаю с NI myRIO, в среде Labview 2013. В моей работе был спроектирован электретный микрофон. Моей страной была запись данных, с микрофона, в массив nx1 (n-строк, 1-столбец). Но в моем случае в массив записывается всегда одно и тоже число. Файл прикреплен.
(4,016 Views)
Accepted by topic author Юлия_96
All you do is creating a 3D array of the newest data.
Get rid of the inner FOR loops, place an initialized shift register on the outer while loop, and append the current data to the existing data using "built array", creating an evergrowing 1D array (ultimately, you'll run out of memory, of course).. There are plenty of examples if the forum.
(4,051 Views)
Here's how it could look like.
Note that "built array" is in concatenate mode and that the indicator has been changed to a 1D array.
(4,049 Views)
Thank you so much!
(4,039 Views)
Edit because of misreading…
(4,038 Views)
