The sample rate in my code is too low. Is there a way to make it run faster?
Dear Sir,
    I am a LabVIEW customer, and just have a question about LabVIEW.
    We are running a code of "Wirebonder Project", but find the sample rate is too low. I'm wondering if there is a way to make it run faster. (I have
attached the code here.)
    Thank you very much!
Yours Sincerely,
Xian Zhang
(2,463 Views)
Hi Xian,
What system are you running this code on and are you using the LabVIEW Real-Time Module?
As you can see, this is not a simple question, so take a look at the information in these links and see if you can narrow down what in your code is running slowly and how much you might be able to improve the speed.
Stephen S.
Applications Engineering
(2,419 Views)
