The set of blinking delay in options not effects in runtime
hi All
I found a problem with the property node of blinking which is that:
I set the blinking delay to 200ms in options first and then use the property node of blinking to set a LED to blinking, which is effective in developing environment. But it is not effective in runtime environment after I build the codes to exe, the blinking delay is always 1000ms.
The version of LabVIEW I used is 2011 sp1, could anyone help me to resolve this problem? Thanks a lot.
(3,487 Views)
I was able to recreate this but I don't see a workaround. I don't use the blink property myself.
(3,485 Views)
Thanks for your reply.
Is there a workaround using the blinking property node?
(3,481 Views)
Did you actually modify the ini file that is created for the exe?
(3,480 Views)
I searched for the correct key field but came up with squat.
(3,470 Views)
Accepted by topic author Tom.Ba
Belay that.
Edit your "application".ini file and include "blinkSpeed=200"
(3,467 Views)
Thanks, it does work. Smiley Happy
(3,457 Views)
