The structure of binary waveform file saved via OWON Oscilloscope PC Suite
I am using OWON TDS8204 oscilloscope together with software Oscilloscope PC Suite for TDS series that I got from the official site.
This software allows to automatically save the current waveform in bin format. The problem arises when I try to parse the resulting file.
Through tries and errors I have realised that data (i.e. points of the waveform) usually (but not always) starts with 279th bit and is 8-bit integer. But values of amplitudes are different from the real values (or those that I get if I save the waveform in csv or txt format): they seem being multiplied by a factor of 2.5 . But I cannot be absolutely sure about this. More over, I suspect that before the data (i.e. the first 278 bits) there is some setup info which is very useful and sometimes is necessary information.
I would appreciate any help with my problem. Examples of saved forms are applied. I cannot attach bin file for some reason.
Thanks in advance.
(5,287 Views)
Hi LRDPRDX,
can't you attach ZIP files?
And can't you ask those, who sold you that software, for a manual?
(5,264 Views)
First of all, I wrote to email address from the official site. I have no answer yet. Secondly, here is zip file with saved waveform in three available formats.
(5,258 Views)
Hi LDX,
the data is stored as bytes starting from byte 278 (first byte = index 0). The last byte in the file is a LineFeed and should be discarded.
The value of the bytes is calculated as float value := 0.4*byte value+53.2 (for whatever reason)…
The content of the first 278 bytes is to be discussed with the manufacturer of your software.
(5,253 Views)
