The switch is ON in the normal state and when it is pressed it turns off.
When the switch is in normal state it is on and when it is pressed it turns off. I need the opposite functionality i.e. when pressed it turns on and when released it turns off. How to implement this?
(2,315 Views)
Accepted by topic author Neha987
Hi Neha,
Options:
  • put a Negate function after that switch…
  • swap the boolean button images (by customizing the control!)
(You should have learned about "control customization" from your other lengthy thread!)
(2,287 Views)
Thank you 🙂
(2,253 Views)
