The template descriptor does not contain data required for scale-invariant matching
I am a beginner, I'm making a key pattern matching with labview
The problem is when I turn on the scale function from the IMAQ Setup Match Geometric Pattern 2 - match mode , it says the template descriptor does not contain data required for scale-invariant matching ,
here is the function in vision assistant
I'm not really good at this , thanks in advance , file as attached below
(key4.png as template , 199810.jpg as the main picture to analyze)
Message 1 of 1
(999 Views)
