The version you requested is greater than the highest version licensed on
I get this error message when starting fresh installed Labview 8.2. Do I need to update the license file on the license server? How do I get this?
(3,424 Views)
I am not sure if that is why you get the error message, but you can check you licence by running the licence manager.  It should be under the National Instruments folder in the start menu.  Search the tree for labview 8.2 and check to see if it is activated (solid green square LED).  If not, you can activate it from the licence manager if you have you serial number handy.  It will connect to NI server and request and install the licence.  Select the software and hit the activate button at the top (or right click).
Message Edited by paulmw on 10-25-2006 07:41 AM
(3,406 Views)
