The view of simulation loop changed
Hello
I am working on LabVIEW / Control Design and Simulation. I want to check the value of a wire inside the simulation loop by a Probe. In the Probe Window I chose "Show Wire", after that the view of the simulation loop totally changed !
My question is there a way to return the view the simulation loop to default ??
Thanks a lot
(2,440 Views)
can you explain your behavior in more details or with a screenshot?
Because I did not find "show wire", I only found "find wire" and clicking on that did not change anything, besides that the wire was highlighted.
Best regards
(2,353 Views)
