Themocouple USB-6353 3400 Celcius
Hi Everybody
I have connected a thermocouple K-type to pin 55,56 on a NI USB-6353 board.
I have then tested with both MAX and LabVIEW: Thermocouple -SW-Timed Input.VI if the setup works.
The temperature input is what to be expected, except in both test set up, it display a temperature of 3400* Celsius often. This temperature is shown more if i physically touch the leading part of the thermocouple.
I have tried with different thermocouples, but have the same errors.
What could course the spike in temperature reading?
(365 Views)
@jolykj wrote:
Hi Everybody
I don't have one of these boards, but the manual shows that pins 55 and 56 are AI Gnd and AO Gnd.  This seems "wrong", to me.
Bob Schor
(328 Views)
Hi Bob
It would have been nice if that was the mistake, so i appreciate the answer 😄
But sadly i use the USB-6353 and not the PCIe-6353, i assume you have looked on this:
https://www.ni.com/docs/en-US/bundle/pcie-usb-6353-specs/page/specs.html
(309 Views)
Oops!  I didn't notice that the Spec sheet listed both the PCI and USB devices, and their pin-outs differed.  My apologies!
Bob Schor
(300 Views)
jolyky,
Signals like that typically indicate an intermittent break in the TC circuit - such as a loose connection.
-Dave
(273 Views)
Double check the terminal connections and the wiring.
Try replacing the wires and ensure they are properly attached to the terminals.
(261 Views)
Could be electrical noise, is the T/C mounted to something or in free air? If connected then provide details.
-AK2DM
(167 Views)
