There are bugs on sub-panel displaying graph
Dear all
I use LabVIEW 7.1.
When I use sub-panel to display sub vi which include the 3D curve graph, the 3D curve graph which displays in sub-panel will move to other position and also cannot be controlled by position property node. How can I solve this problem and why does this phenomenon occur?
The text in the label of vertical axis(y-axis) of waveform graph which display in sub-panel will change to highlight black which cannot be veritfied. I can use picture to instead it, but the label will change position when auto scale, so it is not a good method. Is there other suggest?
Bell
Message 1 of 8
(3,905 Views)
Can you attach a small example program that shows the problem?
Message 2 of 8
(3,904 Views)
Sorry! I haven't upload place.
I describe more detail. When use more than one sub-panel i.e. two sub panels which contain 3D curve in tab, one of 3D curve of two sub vi in sub-panel will move position.
main(contain 2 sub-panel)--> 2 sub vi(contain a 3D curve in a tab)
Message 3 of 8
(3,894 Views)
I kind of understand what you are doing, but I really need your code.  You can upload your code with the "Add Attachments" link below.  (I assume you have the code).
-Matt Bradley
************ kudos always appreciated, but only when deserved **************************
Message 4 of 8
(3,891 Views)
I meant -- the "Add Attachments" Link below your reply when you start typing your new message.  Just hit "reply" and you'll see it below the Tags box.
-Matt Bradley
Message 5 of 8
(3,890 Views)
Message 6 of 8
(3,882 Views)
I'm unclear as to what exactly the problem is. This attachment is a good example of subVIs inside a sub panel, but it does not demonstrate the problem as far as I can tell. Can you find a good way to demonstrate the problem?
Stephen B
Message 7 of 8
(3,843 Views)
Yes, show us how you use the "position property". 🙂
Message 8 of 8
(3,839 Views)
