There is a function in excel called 'linest' that will perform a multiple linear regression with a single y column of data and multiple x columns. Is there an equivilant in Lavview?
Message 1 of 26
(7,460 Views)
Yes there is,
but it is not provided with the base version of LabVIEW (but it is provided with the student edition).
General LS linefit, and it comes with tow examples: Predicting cost, Linear combinations.
Have a look at the Curve Fitting palette for other curve fitting algorithms.
Ton
My LabVIEW Ideas
Message 2 of 26
(7,456 Views)
Thanks very much. I am currently working in labview 6.0 and I have found that vi. But it seems limited to processing 4 columns of x data against a single y column. I need as many a seven.
SJH
Message 3 of 26
(7,411 Views)
Maybe the general polynomial fit is what you want?
Ton
My LabVIEW Ideas
Message 4 of 26
(7,391 Views)
The first vi ispeforming a mulitple linear regression - so you are right, it just does not appear to work as well as 'linest'
SJH
Message 5 of 26
(7,369 Views)
*****UPDATE********
I have been working on this on and off (fortunately it is not that urgent!) and I can use the multiple linear regression but it appears that there is a limit to what the function can perform. I suspect that it is because it is 16 bit. (numbers above a certain value cause problems).
Is anyone aware of a 32 bit version that performs multiple linear regression?
SJH
Message 6 of 26
(7,040 Views)
After more detailed looking, the restriction appears to be the number of 'variables' that the fucntion can process. Above 5 o(i think) the function will not work.
The restriction appears to be at 'code' level - that  I cannot  access. Has anyone any experience of amending labview at this level?
SJH
Message 7 of 26
(6,713 Views)
The general LS linear fit VI should be able to solve your problem.  I implemented an example pulled from the Excel documentation (scroll down to example 3) in LabVIEW.  Excel returns the same results as LabVIEW for this problem.  Attached is the example.
-Jim
Message 8 of 26
(6,667 Views)
Can you attach some typical data?
I suspect that your problem is ill conditioned. What is the condition number of the matrix (try this VI). Have you tried some of the other choices for the "algorithm" input?
I have used this function for much larger numbers of components, so there is no inherent limitation. (It has nothing to do with bits, calulations are done in DBL, which is 64 bits.)
In newer LabVIEW versions the general LS fit tool has been updated and improved. Still, it gives the same result in Jim's example above.
Here's another alternative to add the column. Same difference. 🙂
Message Edited by altenbach on 08-20-2009 04:49 PM
Message 9 of 26
(6,660 Views)
Thanks gents - this now working. I wasn't ensuring that there was the correct number of rows and columns for the function to work.
A little off line playing and your pointers has resolved this.
SJH
Message 10 of 26
(6,639 Views)
