There was a problem installing labview2022 with NIPkg
  1. I downloaded the labview2022 64 bit community version from the official website and downloaded and installed the Ni package manager. I put the downloaded LabVIEW in the root directory of Disk C and clicked install. This problem occurred.
  2. I checked the error log and searched the error code -125560, but I didn't see any related posts. I hope to get your help.
  3. I also checked the properties of the temp file and found that it is normalSnipaste_2022-06-23_21-54-30.png
(1,164 Views)
There is no LabVIEW 2022 community edition (and the community edition is also only 32bit.).
(LabVIEW 2022 is currently in beta and if you are using that, you should give feedback in the dedicated beta forum)
It is not clear at all what you downloaded and from where. Can you show us the link you used?
@desaice wrote:
  1.  I put the downloaded LabVIEW in the root directory of Disk C and clicked install. This problem occurred.
It is generally a very bad idea to manually put any files in the rood directory of the boot drive. Why would you even do that?
(1,151 Views)
1.This is the file and download link I downloaded. I'm sorry for the error in my previous description.
https://www.ni.com/zh-cn/support/downloads/software-products/download.labview.html#343639
2.At first, I put the downloaded files in the download directory. Because my user name is in Chinese, his file address will appear in Chinese, resulting in errors. So I simply put him in the root directory. At the same time, I didn't realize what the problem would be.
(1,127 Views)
