Thermocouple SCXI 1102 and 1303
I am using five SCXI-1102 and Terminal box SCXI-1303 to measure temperatures from 150 thermocouples and then display the data into one array. I only found information and vi example code about acquiring value from one thermocouple, not multiple ones. Could you tell me how to do multiple measurements or find similar example code for me?
(2,684 Views)
Try the Acquire N scans example.
That shows you how to scan multiple cards in an scxi.
Modify the result as it does in the thermocouple example
Greg Bush CLAD
(2,677 Views)
You can also try the attached VI that was built by a customer in the past. I haven't had time to try it myself, but it might be worth trying it.
Please let me know if helped.
thanks,
LA
(2,666 Views)
