Thermocouple and SCB-68
I'm looking at a colleagues code on a teststation.  He is using a Type J thermocouple tied into a scb68 connector 0 on a PCI-6229 DAQ.  He configured the daq correctly in MAX...connector 0 has an accessory w the thermocouple box checked.  If I look at the scb 68 specs it looks like I have to use AI0/AI8 as a differential measure to measure temp.  My colleague is using AI1/AI9.  He is also using daq assistant in his code.  He has chosen the correct setting in daq assit..thermocouple/on board cjc..etc.
My question is:
Can you use any  analog channel in on the scb68 to measure temp or does if have to be AI0/AI8...
Also, how do you select differential in DAQ Assistant??
Thxs..
(3,030 Views)
Keep in mind the SCB68 is just a connector that exposes the terminals of the PCI card. I looked at the PCI-6229 card and I saw no mention of thermocouples, so I'm not sure if it is capable.
(3,007 Views)
Hey gregoryj,
I realize the SCB68 is basically a breakout box for the daq card.  You have to configure the switches correctly and the accessories correctly in MAX because of the CJC on the SCB68.  When I looked at his LV code he is using daq assistant, obtaining "x" number of points...taking the RMS value then converting to temperature in "F".   (9/5*C+32).  I'm guessing he is doing this because as I said he setup DAQ Assit to measure "thermocouple" and the "on board" CJC.  I looked further and found the SCB-68 User Guide and SCB-68 User Manual for Advanced Functions.  On pg 6 , opt 3 of the user guide it shows how to config scb68 for temp/differential so that kind of answered one of my questions.  But the 3rd opt says its read on  AI0/AI8.  So is that the only channel I can use for temp measurement?
(2,983 Views)
The specs for that card say that it has 32 single ended or 16 differential analog inputs. So you should be able to use 15 other inputs besides AI0/AI8. In some places it is labeled more clearly as AI0 (AI0+) / AI8 (AI0-), AI1 (AI1+) / AI9 (AI1-), etc.
Take a look at page 3 and 9 of this SCB-68 label.
(2,975 Views)
