Thermocouple autozero
I'm using NI4350 PXI module plus TBX 68T accesory.
Here's my rpoblem:
Although the TBX accesory clearly has a Auto-zero chanel (CH1), everytime I try to use it in labview with the apporopriate drivr VI ,it creates an error.
Why??
(2,873 Views)
er whats the error please? could you post a screenshot of the block diagram
will make things easier for people to help you
Please remember to accept any solutions and give kudos, Thanks
LV 8.6.1, LV2010,LV2011SP1, FPGA, Win7
(2,868 Views)
Accepted by topic author Miles3
ok i found the problem:
Go into max
go to the 4350 card
properties
add accessory
TBx 68T
click ok
(2,867 Views)
cool, if you can may be worth marking the solution so others can find it easiliy
(2,865 Views)
