Hi Ip,
You can just connect your thermocouples to the relevant terminals on the SCB-100 and then use the built in CJC thermistor device to measure the ambient temperature of the room. The transducer, used for cold junction compensation, is a thermistor. It is calibrated to match the following equation:
TC = 100 * Vt
TK = TC + 273.15
TF = (9/5 * TC) + 32
where Vt is the temperature sensor output voltage. TC, TF, and TK are the temperature readings in degrees Celsius, Fahrenheit, and Kelvin, respectively.
The SCB-100 has dip-switches that will enable the CJC. Refer to the appropriate installation guide for the correct dip-switch settings. After setting the switches, the CJC transducer is connected to Channel 0 of your data acquisition (DAQ) card. If
you are using NI-DAQ, create a virtual channel in Measurement & Automation Explorer (MAX) that reads Channel 0 to see the temperature the CJC is reading. If you are using NI-DAQmx, you create an NI-DAQmx Task instead of a virtual channel. The link below might be useful.
http://www.ni.com/pdf/manuals/320907a.pdf
Hope this helps.
Nick
