Thermocouple measurment using NI 9219
I have a NI 9219 and an omega j type thermocouple,
When i connect the thermocouple to NI9219 terminal 4 and 6 ( positive and negative terminals) and open up Signal express I don't see the voltage change! is there something else that i need to do before i can see the measurments?
(3,426 Views)
I'm using the USB9211, and had to get the max and min voltage set right before it would display.  It had to be between 8.0e-3 and -8.0e-3 for us to get a good reading.  Not sure if this will help, but if so, great!
Matt
(3,405 Views)
Hi there
you have to use terminals 4 and 5 for thermocouples. See page 11 on the user manual: https://www.ni.com/docs/en-US/bundle/372407a/resource/372407a.pdf
Best regards
chris
CL(A)Dly bending G-Force with LabVIEW
famous last words: "oh my god, it is full of stars!"
(3,378 Views)
That is correct. In my experience (the little there is), thermocouples are almost always in adjacent terminals
Message Edited by Cory K on 01-02-2009 10:41 AM
Cory K
(3,366 Views)
