Thermocouple type K displaying wrong readings
Hi Doha,
I am trying to average the temperature readings per hour over a number of hours.
Lets assume your DAQAssistent delivers meaningful values with unit °C like 25°C (average lab room temperature).
Why do you think it would make sense to divide those readings by the "sample per hour" value resulting in values of 2.5 for "10 S/h"???
Why do you think division is the very same as averaging?
Why don't you use a Mean function???
i use DAQ ASSISTANT because i don't know any other tool that i can use.
LabVIEW comes with a huge example library. None of the DAQmx examples is using the DAQAssistent…
Btw. right-click that DAQAssistent and select "Open Frontpanel" to see the functions you can use.
I used a FOR loop inside another as this is what i felt was an appropriate method to generate the results.
Do you program by your "feelings" - or by developing an algorithm?
(I often suggest a pen and a sheet of paper to develop an algorithm BEFORE even starting to code using LabVIEW or any other programming language…)
Message 11 of 13
(707 Views)
no i didn't make the thermocouple myself, i purchased it.
yea i guess i probably need to test it using another device, thanks alot.
Message 12 of 13
(692 Views)
Yea alright i'll check that but apart from the VI.. I still get the same problem in the NI MAX
Message 13 of 13
(688 Views)
