Thermotron 8800
Both 7800 and 8800 controllers have 'gsoak' or guaranteed soak intervals allowing you to set a final temperature and then wait until the chamber actually reaches that temperature.  Check your manual for gsoak...
Message 21 of 40
(3,415 Views)
I just started with TH8800-8200 and found this thread is intresting. I have a thermal profile and like to programatically control the therotron through LabVIEW, I downloaded the drivers and looking for the perfect functions for my requirements. I hope you guys already did the same excercise, if anyone downconvert the VIs to 2009 will be helpful.
Balaji PK (CLA)
Ever tried. Ever failed. No matter. Try again. Fail again. Fail better
Don't forget Kudos for Good Answers, and Mark a solution if your problem is solved.
Message 22 of 40
(3,383 Views)
Please post your vi so I can download it or a code snippet png
and I will try it here at the factory and see what is wrong...
You are communicating to an 8800?  What are the 8800 serial port communications parameters?
What version of LabView are you using?
What OS?  64 or 32 bit?
Monte VanNortwick
Message 23 of 40
(3,374 Views)
Hi, I am trying to locate a Thermotron VI for the 8200 ESS chamber with version 8.21.
Rulee
Message 24 of 40
(3,229 Views)
You don't need a vi.  Just look at the computer IO command set in the 8200 manual and use this example to get started:
http://www.thermotron.com/sites/default/files/pdf/Example_Three.png
Message 25 of 40
(3,222 Views)
Care to explain the you don't need a VI statement?
Message 26 of 40
(3,217 Views)
Thanks, I will get started!
Rulee
Message 27 of 40
(3,218 Views)
Message 28 of 40
(3,210 Views)
Thanks, I have problem, I have Lab View 8.2.1
Rulee
Message 29 of 40
(3,206 Views)
This example will still work with LV 8
Message 30 of 40
(3,203 Views)
